Ender 3 V2 Help
Hello all
I just purchased an Ender 3 V2 and assembled it, however, it keeps on moving to the corner of the bed and begins printing off of the print bed. I have attempted to update the firmware but it made no difference.Thanks for the help
@zm0000001
92.6 is your factory setting, ok.. if you extrude 100mm measured (filament marked at 100mm and 120mm from the last input access), what is your result??
note: 120mm mark is useful if your test use a bit more than 100mm..
@Helium3 The steps/mm E is 92.6
@zm0000001
you have to go in your display/console menu..
in my case:
Menu > control > motion > steps/mm > Esteps/mm
and there is the factory value..i have changed this value, confirmed my 100mm test, gone to up menu until to see « store setting » and clicked on it (and beep!).. after that i have switched the power off/on and confirmed the new value stored in the EEprom..
your menu should have similar options!
@Helium3 Where exactly can I see the offsets?
@zm0000001
hi, can you confirm your x/y offsets value?
it’s in the setting of the console..
may possible to have a factory wrong value..
someone can to confirm well working values here?
Hi, @zm0000001 Could you please send a video that clearly shows the issue. You can send an email to cs@creality.com and attach a video. There will be professionals to help you.
