Issues with the temperature setting.
  • I'm having an issue with my nozzle temp. when I click "preheat PLA" it is set to heat up the nozzle to 200 (it does this fine) however, as soon as I click on a file to print it the temperature automatically changes itself to be set to 150 and sometimes a few seconds after that it will reset it self but back up to 205 so I have to go in to "tune" and set it back to 200 every single time after I hit "print"
    any ideas why this could be happening?
    This is my first printer so I am very new at this!
    Thanks!😊
  • @sanhiram
    hi,
    that may your first layer temperature setting in your slicer?
    can you confirm it??
  • hello,@sanhiram From your description, you should confirm that the nozzle temperature is set at 200℃ during slicing;
    And PLA can be printed at 200±5℃. If the printing quality is not affected, there is no problem to maintain 205.
    If the above methods do not work, try to update the firmware.
