You can NOT edit G-code so if using bltouch or Cr-Touch it dose not probe the bed just gets Z home position.
@Gracy
thanks Gracy, itβs almost the same on Cura 4.10.0:
go to <Settings>
-> Printer
-> Manage Printers... will open the Preferences windows
-> Machine settings
the G-code for Start/End appear at the bottom and can be edited there..
@Gracy ok thank you. i will give this a try. and see if it changes anything. i will also make a video of process to show process problem & results.
Hi, @C3DS Wifi box is just to support online printing, and more functions are still under development.
You can refer to the following pictures to edit the G-code in the Creality slicer.
@Gracy not when sending from Creality cloud using the WiFi box. If so can you link or post instructions on how to change. Please thank you.
Hi, @C3DS G-code can be edited in the Creality slicer.
