CR 10 smart not sticking
  • I use a cr 10 smart 3d printer and it's been working fine for the last part of the two weeks I got it.
    But however this morning I tried printing a cylindrical part and the first layer isn't sticking to the bed. The nozzle keeps extruding filament but the filament just goes on a straight line not sticking to the bed.
    I'm certain I might have tampered with some settings maybe but only on the printer.
    As I've printed that part multiple times before without issue and it's the same g code
  • @Centauri
    I got bed adhesion problems that cleaning bed or drying filament didn’t resolve. Not with PLA that sticks ridiculous well. But with PETG.
    I figured out a little simple glue stick procedure that was superior to just smear around a thick layer of glue.
    I put glue on a 50mm circle in the center. Then I take the corner of a wet piece of cloth and work out the glue to an thin invisible film that is quite tacky.
    The thin film is easy to clean up compared to a thick layer of glue and the prints stick very well to the bed. Not a single issue after that with that brand of PETG which was impossible before.
  • @Expee If its a new printer and has been working OK for the last few weeks, do not use glue or any other kind of layer on your bed. Basically, if it wasn't necessary during the last few weeks, it shouldn't be necessary now!
    The bed may need cleaning, especially if you have been touching it with your fingers. This is best done using a small amount of Isopropyl Alcohol (99.9% Pure IPA) with a clean cloth. When the printer is not in use, cover the bed to stop the build up of dust, and/or gently wipe the bed with a clean cloth before use (...don't wipe the surface with your hands!).
    If you have been printing with the same filament for the last couple of weeks, and have left the filament on the printer between prints, it may have absorbed moisture from the air. This may affect its performance & ability to stick. I suggest you invest in a cheap digital hydrometer. Keep an eye on the relative humidity and avoid leaving filament reels out if the RH is greater than (say) 50%.
    Silica gel is great for storing filament, but it is not a magic solution; every time you take out a filament reel and subsequently put it back into a storage bag, you change the air in the bag. The silica gel then very slowly absorbs some of the moisture, as long as the silica gel is not saturated.
    Check and clean the outside of the nozzle to ensure that as plastic is extruded, it is not sticking to the nozzle. Also make sure that there is not a bead of plastic on the tip, as this will give you problems when trying to level the bed.
    Investigate non-stick problems by printing small objects (i.e. those that can be printed in a short time; say, <20mins). Do these test prints near one of the front corners of the machine; this is because it is easier to make adjustments to the leveling on one corner than it is when you print in the centre of the bed. If you can get it to stick in a corner, you should be able to fully level the bed and then it should stick in the centre (...actually, I don't print anything in the centre of the bed, unless it is a very large object).
    I hope this helps.
  • Hello Expee,
    I think it might be of 3 reasons
    1. the bed temperature might be too cool. For many filaments (excluding pla usually) you need a certain warmth level in order for it to stick to the bed.
    2. The bed might be too low. The distance from the extruder could be too far from the bed so it's the extruder has moved on before the filament has reached the bed.
    3. You might have bed adhesion issues. I do believe that the CR-10 Smart has the type of bed that's really sticky like my CR-10 V2, but you never know, it might have been damaged. The is probably not the issue, but you could try putting some glue (not the liquid kind) on the bed and it might help if it's the bed's issue.
Copyright © 2020 Shenzhen Creality 3D Technology Co., Ltd All Rights Reserved.
