None of the motors are working
None of the motors are doing anything. The screen turns on, The LED light and all the fans work. Print head and bed do nothing. Everything is plugged in. Checked all the connections. voltage to and from the power supply are good. Tested the cable from the screen interface to the board, no problems.
Any ideas?
Is it this the same problem here?
I also have this problem.
- Please check whether the power supply is adjusted to the local voltage;
- Measure the output voltage of the motor port on the motherboard
- Measure the input and output voltage of the power supply
