Issue with homing on new Ender V2
I just built my EnderV2 and upon turning it on and selecting "Auto Home" the extruder immediately moves to the left but does not stop when it hits the limiter, the motor continues to try and pull the extruder farther to the left. This happens on both the vertical and horizontal axis.I cannot print because of this, any help is appreciated.
hello, @thebozzz From your description, you can try the follow methods:
Check whether the limit switch wiring of X axis and Y axis is connected rightly, and whether the limit switch wire is damaged;
Detect the voltage at the interface of the upper limit switch on the motherboard, if it is 24V, then the motherboard has no problem, please change the limit switch; otherwise please replace the motherboard.
