Cr10s Pro v2 Thermal issues
  • Hi,
    I have a CR10s Pro V2 that's less than a year old.
    The nozzle temperature is stuck between 115 min and 180 max. When I try to heat it up to 210 the thermal protection kicks in and the hot end was visibly smoking with burnt pla.
    Here's the steps I've taken so far:
    Replaced Thermistor - Creality branded (no change)
    Replaced Heater Cartridge (no change)
    Unplugged the thermistor and heater, turned on the machine, Temp still shows 110
    Flashed firmware with from Creality's website (no change)
    At this point I am not sure what else to do with it, perhaps it is a main board issue? if so, is it covered under warranty?
  • @Helium3 said in Cr10s Pro v2 Thermal issues:
    @Phantom
    hi,
    have you open the console and checked if anything is wrong/burned/suspect? ..often when something stop working after a while, something is visible somewhere!
  • @Phantom
    hi,
  • hi,@Phantom according to your description, it is probably that the motherboard is broken. Try to repalce a new one.
