Trouble Shooting for Stepper Motor
  • If the motor pause,abnormal sound, reverse, or does not work, what can we do?
    The following are some solutions for reference:
    1. Make sure that the limit switch is not pressed and is open. Check the stepper motor cable.
    2. Replace the motor wiring with the replacement method and ensure that the limit switch is not pressed.
    3. If the motor still fails to work after changing the line, and confirms that the line is normal, then replace the motor with a new one.
    4. If the replaced motor cannot work after changing the line, and confirm that the line is normal, it is a problem with the drive. Then replace the mainboard with a new one.
