cr touch mesh saving to sd?
When you use the "level" option on the main screen does it save the mesh to the sd card or do I have to run that before every print? (ender 3 v2)
@C3DS i would actually prefer not to run it every time. My bed stays level enough that I rarely had to do it before the cr touch.
@thecbrguy Need to edit your start G code after it says G 28 you need to add G 29 and it will automatically do a bad level before every print
