Redesign plastic housing cr-6 max
  • When i remove the metal cover that holds the part cooling fan if i am not careful the left screw can drop down and go through the hole in the plastic mounting for the small board.
    Could the hole be a grill instead to stop this happening as it may cause a short if the screw is left there
    It is annoying having to dismantle it to recover a screw
