Motor Y problem
Hi all, i have problem with Y motor ( i think). I send a photo how my ender 5 pro print models. Does somebody know why it is happening ? Must change stepper motor ?
@emilos6222
have you checked if any wire from the y axis stepper motor is slack at the connector of the driver?
@Helium3 i saw once how it looks like. Theo motor Y try rotate but it can't during Y coordinate changes values. After a moment it sudennly can rotate but Y coordinate is different than it should be.
@emilos6222
hi,
have you inspected the belts and steppers gears? ..if to much used (or if some tooth are missing) will cause slipping during the print.. also check the belt tension, just in case..
