Help with new E3 V2
Ive put my E3 together and set it all up but couldnt read from the SD card. So I formatted the card and just put one gcode file on it. Didnt work. Now the printer wont home and if you try you hear a clunk and then nothing. I cant upgrade the firmware as it cant see any card. Can anyone help please?
@Mark-Mm
my cr10 can only work with 16go or less.. have you tried it??
Oh, BTW windows will report that there is something wrong with the card, and wants you to reformat it. Just give it a minute and it will then be able to see the card.
I was not home when I make the post above. It is formatted in FAT32.
I believe the SD card is formatted in either FAT or some form of FAT. More than likely you formatted it in NTFS which is the native format of Windows 2000 and up to windows 10. Need to run a SD card formatter.
