Direct Drive + PETG
  • Will the Ender 3 V2 direct drive hot end upgrade be hot enough to print PETG. I have the glass bed do I have to change it in order to print PETG or will glue stick be good enough?
  • I have moved on from PETG to ASA. My best results were 245 Nozzle 95 bed. I wiped the bed with alcohol. Biggest problem is that the edges would like to curl up. I fixed that by raising the bed up another 5 degrees.
