New User
  • Got an Ender5 pro for Christmas. Between the included poor instructions and the better YouTube video, have it built. Leveled the plate and printed the dog.g code from the sim card included and using the filament included. It came out like a badly weaved statue. Nozzle temp was 200. Any help will be appreciated!!
    Ed
  • It's been several days and I have made a lot of progress. I think with that cat, the problem was that the filament was hung up due to being over-wrapped on the spool. I've had it happen a couple of times. 99.9% of the time the model does stick to the build plate.
    I was using Creality's Slicer, but switched to Cura since it seems to be easier to use and have more options. I am learning about supports and how to tweak them.
  • @amrap Nice! Actually, the body of the creature looks pretty good!
    But it looks like you are trying to print the tail without supports (i.e. trying to print in mid-air).
    Did the creature remain stuck to the base-plate (bed) or did it break away before finishing the print? Without seeing a picture of the completed design, I can't say whether the problem with the head is also due to over-hangs.
    So in the slicer software, you need to select General Supports, Touching Buildplate (or whatever the equivalent is in your slicer) for this particular model.
    Loaded file from Thangs into Creality and saved as gcode. This is how it came out.
  • Check the filament. I found out the hard way that the free reel that came with the printer was PLA+ not PLA. I'd not heard of PLA+ before then and as they hadn't shipped the PLA bundle I ordered (without telling me, I had to chase them to find out what happened to it) it was all I had. My symptoms were no bed adhesion (my own small prints, I didn't try the examples)
    PLA+ has much higher temperature, I'm using 220 compared with 180 for PLA on my old Reprap Mendel.
  • @amrap OK, so the original filament can be dried out in an oven. BUT you must use a low temperature or run the risk of the filament going soft and changing shape. So if you want to try this, I'd suggest setting the oven to about 30'C in 'fan assisted' mode and run it for about 4 hours.
    When not in use, put your filament inside a plastic bag with silica gel (see my notes: http://captainbodgit.blogspot.com/2021/08/3d-printing-humidity-keeping-your-pla.html )
    When you say that the printer only prints in the corner, and that the 'pattern is the same' please explain further.
    When the printer has been correctly set up, the print position is determined by the sliced object; i.e. if you slice with the object in the centre of the slicer platform, then that is where it should print. However, if the entered values for platform size are incorrect in the slicer, the printer object may be printed off centre.
    What slicer software are you using?
    I would also recommend that you download a calibration cube from Thingiverse, slice it using Cura, and then print it. It will provide quite a bit of info about how well your printer is running and speed up diagnosis of any problems: https://www.thingiverse.com/thing:1278865
    I hope this helps, but come back if there is something you do not understand.
  • @SteveDee I changed the filament and it seemed to be working. Most everything printed fine but now the printer only prints to the rear right corner and the pattern is the same no matter which file I load.
    Don't know what to do now............
  • If you are new to 3D printing, there is a lot to learn.
    Some users have reported having problems with the free filament provided with the printer. If you curl the filament into a "U" shape and it snaps easily, the filament may have soaked up too much moisture from the atmosphere and may give you printing problems.
    But what we really need from you is a photo of your printed dog.
