Stuck in splash screen, won’t boot up
When I turn on my printer, I see the Creality name on the touch screen with a progress bar. But it never gets past this screen. The printer won’t boot up. I have not yet tried to reinstall the firmware. Hoping this will fix the issue.
@admin I tried, but didn't work. Here's what happened:
I just got my printer, unboxed it, set everything up, and powered it on. It booted up fine, I did the auto bed-leveling like it said to in the manual. But when I inserted the sd card to try to print something, it couldn't read the files. So I turned it off, went to my computer and moved the g-code files to the root, put it in the printer, turned it on, and I'm stuck on the splash screen. I pulled the sd card out and tried again - stuck on splash screen. I followed the firmware upgrade info and put the .bin firmware file on the sd card, power on - stuck on spalsh screen. I don't know what to do. Any other help?
So far, I have been unsuccessful. My printer is still stuck in the boot up screen
I have the same issue. Did the above solve the problem by any chance?.
@MattySarv just got my printer today, same issue. Won't even get far enough to update the firmware. Did you figure out a fix for this?
@MattySarv
Try Download the firmware from here: https://www.creality.com/download.
and flash the firmware as the tutorial said:
Mainboard Firmware Tutorial:
https://www.youtube.com/watch?v=AKIfwPgN0qs&feature=youtu.be
Screen Firmware Tutorial:
https://www.youtube.com/watch?v=Jswzrh2_ekk
