Auto home y axis does not want to home
Need help,
Just got my ender 3 v2 last night and when doing auto home, y axis stays the same no matter where it currently is
I did a couple of prints and the y works perfectly but moved the y axis manually before starting the print to "home" it (while the printer was turned off)
Even reflashed the firmware and checked if all the connections are good (on the motor, switch and board inside)
Seems to me like a firmware problem because when doing auto home it doesnt even try to home y axis and hit the limit switch
Also for some odd reasone most of the connectors on the board are hot glued together (idk if thats supposed to be like that or not)
