3D Model Hotend Fan Air Distributor
Hello together,
because the orginial Hotend Fan Air Distributor of the CR-5 Pro H is ugly printed and also had a one sided air Flow to the Nozzel, i have designed a new one, which had an air distribution around the nozzle from almost all sides. Any distortions caused by the one-sided cooling should thus be improved.Download Link STL File:
https://jmp.sh/eqKtv57Printing parameters:
-Material: extrudr ABS- Skaling: 101% (ABS Shrinking)
- HotendTemp: 255°C
- Headbed: 110°C
- Interior temperature with addional heating system: 60°C
- main print Speed: 60mm/s
- Supports up 45° on on headbed
- Positioning 45° on headbed
Have fun and give me Feedback if it work well or if you had some ideas for improving the 3D Model.
BR
Andreas from SmartMultiCopters
