Problem with Ender-3 slicing software
My Ender-3works very well, but I have a problem with Creality’s downloaded slicer software that doesn’t happen with any other slicer.
Despite ensuring that the “printer temperature“ (ie, nozzle temp) is set at 210 deg in the slicer program, the screen goes to 0 deg when the gcode is transferred to the printer by SD, and I have to dial it up manually. Only then will the nozzle heat up. Why is this, as it is most irritating?
@Silversurfer Use Cura instead, this will fix, add custom printer, this is how it should look like
This is the custom profile which i made: https://dl.uploadgram.me/6242e943f24efg?raw
You can import it through settings->cura->profiles->import
