CURA 4.7 & CREALITY CR-6 SE
Does anyone try CURA 4.7 ? I can't find SE-6 SE from printer list, so i tried add custom printer. I can change all the parameter value from the machine settings exept X min & Y min to + (positive) value, and also how about code for start & end g-code ? I tried to ask about this to creality via email & chat but no luck there. I didn't get a single reply from them. Hope to get solution here.
Thanks. It solved. Just a bit curious, should i change the start & end g-code ?
You can use the machine to choose Ender-3, and the platform size is changed to CR-6 SE.
