Display not showing up correctly after update to 2.0.9
Hello together,
I am trying to install the current Marlin to my Ender 3 V2. For that I have copied the DWIN_SET Folder to the SD-Card, build the Firmware using VS Code and copied the bin file parallel to the DWIN_SET Folder. After that I have plugged in the SD card into the display SD port and powered on the printer. After the display changes from blue to orange, I have powered the printer off.
I removed the SD card from the display and powered on the printer. The result is this image.
Did I forget something? What did I do wrong?
Thanks for your help!!!P.s. what my camera did not captured: the "Home" text is yellow and not white.
