CR-10v3 with CR touch firmware
Hi everybody. I'm new to the 3D printing game and just got myself a CR-10 v3. I'm pretty satisfied of what I've printed so far. I also got a CR touch to improve on my bed levelling. Since I have a CR-10 v3, for what I understand, I have to update my firmware using the USB cable since there's no bootloader on the CR-10. The walkthrough provided by Creality for the installation of the new firmware used with the CR touch brings me to a .bin file which I can't use if I update with the USB cable. I've been looking everywhere for the right .hex file. Can someone point me in the right direction? Thanks in advance.
@DooM1977
For this model it is not needed as it is mentioned here https://www.th3dstudio.com/hc/downloads/unified-2-firmware/creality/creality-boards-creality/creality-cr-10-v3-firmware-v2-5-2-board/
You have to make the firmware by your self because the printer can be flashed by using usb only.
@MM3DMaker Hi again!
Just to be sure. To check the cpu version, do you have to physically look at the chip to see if it's a RET6 or RCT6 or is there another way to see it?
Thanks again for the support.
You can also check this instruction, how to compile firmware for your model:https://www.th3dstudio.com/hc/downloads/unified-2-firmware/creality/creality-boards-creality/creality-cr-10-v3-firmware-v2-5-2-board/
@MM3DMaker Thanks for the quick reply! It's really appreciated. I'm at work right now and I'll try to give you the information you requested as soon as I can so you can send me the .hex file. As for the bootloader, I tried to update the firmware using the SD card and nothing happened. That's when I started doing research and people told me about the CR series not having a bootloader.
On new 4.2.2 boards there is a bootloader, Tell me the cpu version, RET6 means 512K and RCT6 means 256K. i can make firmware
