Ender 5 plus Heats up doesn't start
  • So I've had this ender 5 plus for a year and have had it print fine during that time.
    Then I ran into the issue where it will heat up but not start printing.
    When I use the manual heat up method, it says heating done.
    But if I hit print it will get stuck on heating.
    Match the right temp, then fluctuate above and below the selected temp.
    I replaced the thermister thinking that was the issue.
    But after replacing it I got a heating failed to match the temp warming menu.
    I tried again after doing some PID tuning with pronterface.
    The machine heats up but doesn't print.
    I'm guessing it's a problem with the power supply.
    Any ideas or suggestions appreciated.
