Design a mechanism to prevent the LCD screen from being destroyed during failed print
  • New Halot Sky owner here.
    I recently had a failed print where a piece I was printing broke loose due to insufficient supports. This piece was then mercilessly and repeatedly jammed into the LCD screen by the force of the Z motor / build plate and cracked the edge of the screen.
    Has anyone at Creality considered re-designing the printer so that a failed print doesn't destroy the LCD? Failed prints do happen, and when they do it shouldn't cost $200 to replace the screen.
    One suggestion, design the LCD to be housed in a metal frame on springs. Pressure on the LCD due to failed print would depress the springs. Metal frame would trip a limit switch sending an interrupt signal to the CPU. CPU would then pause the print, sound an alarm, and raise the build platform for inspection.
