Z Axis not lowering after autohome
I have the Ender 3Pro and installed the CR Touch. The Z Axis will work just fine until I do the first autohome. Then it won't lower anymore. I've tried different connections with the Z stop.
Thanks for any advice.
I just posted about this same issue under the "accessories" page. Make sure you have removed the z-axis limit switch, then try again. If that doesn't help, and you have already confirm the proper firmware, wiring, etc, then you are in the same boat I am.... waiting for a response.
