Ender-3 v2 z-axis inconsistent.
  • Hello hivemind.
    I've tried to look up this issue many times, but nothing helps, so I hope you can help.
    My z-axis keeps being inconsistent. When Autohome the printer, the x and y axis is correctly calibrated but the z-axis keeps either hitting the bed or being 2mm from it. Even when manually calibrating the z-axis, it doesn't keep the values.
    It's a new printer and I got no accessories attached.
    I've tried to:
    • switch the z and x endstop, but the issue still persists.
    • updated the firmware.
    • slightly loosen some of the bolts and belts incase of overtightening.
    • calibrating the bed (before I noticed the z-axis being off, which were hell)
