How to Connect a PC?
  • I'm a newbie of sorts, and one of the reasons I bought the "CR10 Smart" was because it has the SD Card reader -plus- a USB port -plus- Wifi... but even with WiFi setup and enabled I cannot see the device on the network. So the WiFi connection is useless. Also, I plugged the SD card into the USB adapter that came with the printer, and plugged that into the USB port, but when I touch "Print" on the menu, it does not display any of the gcode files that are on the SD card. So the USB port is also useless. I haven't yet tried connecting a network cable to the RJ45 port, but I suspect that would not work either. So tell me folks, what am I missing? And FYI I'm a software developer and have built many networks too. This doesn't make any sense...
