Failed layer 1 print
  • Hello all,
    I realize ths might be the most common first post for most members.
    I'm no exception..
    If running at 500% it looks good,, but is way to thick blocking the nozzle printing a second.
    If running att 105%, whispy stringy filaments barely touching the bed...
    I have an Ender 3 with v4.2.2 original, 4.2.7 and even a newer one. Direct-drive extrucion etc. All amazing build quality!!!
    Anyhow, see the pic
    What am I doing wrong???
  • @x-stride firstly I'd suggest not varying the speed. Going faster is something to try once you get everything right at normal speed. A successful print depends on so many parameters and you have not shared any in your post.
    Eg. Bed temperature, filament type, filament temperature, nozzle size, layer height..... would be a good start.
