CR-Laser Falcon Engraver
  • CR-Falcon
    CV-30
    Laser Engraver
  • The CR-Laser Bird of prey highlights what Creality alludes to as 'poly-focal point spot pressure laser innovation', which empowers a small spot size of just ...
    Advantages and disadvantages: Simple to set up ⋅ Smooth and exact developments ⋅ Speed enhancements of multiple times Further queries you have to visit https://lumbuy.com/.
  • Has anyone seen an issue with shifts in the Y-Axis while running a job on the CR-Laser Falcon. The job is a simple one with a few lines of text bordered by a box. Halfway through the output shifts by about 10mm and then later shifts again.
    I'm running Lightburn with a USB connection the engraver.
    Thanks in advance
