Extruder Replacement
  • Hey all, I recently had to open the extruder to clean it out and although it was fairly easy to put back together, finding the right tension has been a nightmare. Has anyone installed a replacement extruder? Does the EZR fit? OR a direct drive replacement?
  • Dear @ewanp
    The extruder is not easy to adjust. It is recommended to heat the nozzle to 200 degrees, control the extrusion to rotate, adjust the extrusion tension, and find a suitable position. It is also possible to replace the extruder.
