Levelling Probe connecting
  • Hi, I have just purchased an Ender 3 S1 Pro and am having trouble with the levelling probe knocking the printed item and it ends up coming loose. Also sometimes the fan bracket also hits if it has to transverses over the printed item. Has anyone else experienced this and is there a fix. There doesn't seem to be any adjustment on either fixture.
    Thank You
  • @woiim With the exception of the levelling probe (when it is lowered to level the bed) the lowest point on the print head should be the extruder nozzle. Have you enabled the feature that allows separate parts to print one after the other instead of layer by layer?
