Creality Sonic Pad on my Ender 3 S1 Pro
  • Hi to all! Need some help, I've been hours trying to level it and still don't have a clean first layer, but in the process the hotend crashed into the bed. Since then the Sonic Pad is giving errors regarding the bed level sensor "Touch Failed to Deply", then says "Must Home Before Probe".... any suggestions??
  • @Dgtxpr Sounds like the CRTouch probe may be broken. When you tell it to home XYZ, does the probe deploy? Can you manually pull the probe tip down a little with your fingers or a tweezers? It really can't crash into the bed unless you told Z to go down too far during the leveling process. You might need to contact cs @ creality for assistance.
