Unable to Stick after fitting BL touch
  • I have just upgraded from an Adventurer 3 to the CR-10 v3 for the larger bed size. I was not confident that I had optimal tramming although I could print some larger objects. Therefore I fitted a BL touch leveller and gone thru the process as per the directions and thought I had it right. But now nothing will stick to the build plate at all. What am I doing wrong??
  • you have to configure the correct Z-offset in the printer too...
