Ender 5 Pro Print start way far from the print bed after installing BLtouch
@admin
I have installed BLtouch as you described in https://forum.creality.com/topic/340/ender-5-pro-v4-2-2-bltouch-installation-question/5
I followed all the instruction and run into a strange behavior.
when i send a print to the printer the print start way far from the nozzle so the filament come out in the air!
the z axes offset is set to -2.3. the print bed at the beginning of the print (when the nozzle start to extrude filament for print) is at z axes +28. way too far.
do I need to adjust this manually during print? this can cause damage to the bed, nozzle and printer overall.
what am I missing?
Thanks,
David
Dear @davidzohar
Please check the video to see if you follow the right way to install the BL touch
https://www.youtube.com/watch?v=Jmu5Fh_nPtw&t=164s
@admin any answer on this? no matter how i set the z offset using the control panel or using gcode the z offset does not saved in the printer.
please help.
