Ender 5 Pro V4.2.2 mainboard with BLTouch - alarm ringing
I am trying to install BL Touch onto an Ender 5Pro with the V4.2.2 main board. I have downloaded the recommended Aug 29 firmware, but once installed, there is a constant alarm ringing.
Also, I notice when I install the Pinboard A from the BL Touch kit, the display does not work.
I have watched all the videos more than once, and still cannot progress.
How do I correct this?
Thank you!
@DennisSamson Problem has been resolved, it was an incorrect connection on my part when installing the Pinboard for BLTouch.
NOTE: When installing the Pinboard on the Ender 5 Pro, the three pins for the BLTouch connector need to be bent 90 degrees to provide adequate space for the cooling fan.
