Sending "M420 S1" gives an error... sometimes. Creality please help!
  • I have been having problems with the auto-leveling turning off. It seems like the bed becomes too close to the extruder and the first few layers are not deposited. the initial wipe/purge pass on the left has now left a permanent streak on the glass plate. It works when I tweak the z-setting 'up' in the leveling menu.
    I thought that the printer might be forgetting to use the leveling data so I started to send "M420 S1" as part of my gcode startup script in CURA printer setup.
    But now I am getting a total shutdown of the printer and an error in OctoPrint "Your printer's firmware reported an error. Due to that OctoPrint will disconnect. Reported error: Failed to enable Bed Leveling". The printer LCD does not report an error but when I try to "autolevel" the screen hangs up at the grid display and nothing happens.
    When I restart the printer and send "M420 V1" in the terminal I get:
    echo:Invalid mesh.
    echo:Bed Leveling OFF
    echo:Fade Height OFF
    What is happening? How can I or you fix this?
  • @spauliszyn : Did you ever figure out if you need M420 S1 or not in Cura ? I've got the same question.. and it sadly doesn't seem to have been answered anywhere on the forum clearly.
  • As an update @admin, I reloaded the firmware like you suggested. Then I leveled the bed and started a new print. It turned out ok. Then I started a new print without changing any settings. The print started with the nozzle touching the plate. Here is a picture and I will explain more below.
    It was during the stage of printing brims. When I caught the problem I started adjusting the z setting manually. I increased it from 0.20 to 0.50 at this stage. Then you can the last three brims being printed ok and then I finally canceled the print while it was printing the first layer on the first rectangular part.
    I also sentan M420 V1 and the printer reported that the ABL mesh was ok.
  • Dear @spauliszyn
    I have sent your information to our after-sales team, and they don't suggest your refresh other company firmware, and they suggest you refresh the firmware on our website: https://www.creality.com/download
    If it not work, I would recommend you send the email to cs@creality.com for more suggestions. Thanks for your support.
  • As an update, even now after an ABL, i have to bump up the Z adjustment in order to get any extrusion on the first layer. I am currently at 0.40.
