How to switch to CURA 4.7
  • If anyone has made a successful switch to Cura 4.7, can you show us how? Is it possible to export the printer parameters?
    I tried it myself but couldn't get it to work. I feel like it should be easy but I think I am missing something.
    Thanks in advance!
  • @Sonics99 said in How to switch to CURA 4.7:
    Thanks, I was wondering about this and if it was a smooth transition to go to 4.8. Were you just able to do an inplace upgrade?
    Not ncbob but I had some snags w/ Cura trying to migrate settings, so ended up clearing the Cura user data folder after installation and starting fresh. Have been using 4.8 beta since it dropped and results have been very good.
  • @ncbob said in How to switch to CURA 4.7:
    @spauliszyn and anyone else who is interested, Ultimaker just released Cura 4.8 beta. I've downloaded it and I'm doing some test prints, and I'll let you know how they come out. It has a profile already set for the CR-6 SE.
  • @spauliszyn and anyone else who is interested, Ultimaker just released Cura 4.8 beta. I've downloaded it and I'm doing some test prints, and I'll let you know how they come out. It has a profile already set for the CR-6 SE.
  • Just want to throw my 2 cents in now that my printer is finally working.
    I used the ender 3 profile then change the bed size, start and end code to what I use normally, and change the retraction to 5.5 and itโ€™s printing great.
  • These files made my day a lot better. Running cura 4.7.1 and its working like a charm.
    Only thing i still ask myself is why the printer always goes to the middle and drops a blob of filament there and then go to the edge to string it. Is there no way to get the nozzle to drop off that blob before it goes to the middle? I am on my first printer and 4th day so i have no clue if this is even possible.
    Thanks again!
  • @Acd75 Crap. Don't have that option with the Ender 3 Pro...
  • @iMars I have generally been getting very nice prints from 4.7.1 - when I have had issues it has been with adhesion, loose bed, or runout detection, which aren't slicer problems. I had heard at least one other report of challenges with 4.7, but I have not experienced any.
  • Nobody issues with version 4.7? I got 4.7.1 and circular/vase prints look terrible. Like it is stuttering. I've been told it is in the 4.7 software and it is better to stick to 4.6.
    And anyone who cares/like to share the profile for Cura (4.6)? I'm using now Ender 3 Pro as printer, not sure if that's good, or can be better with its own CR-6 profile?
  • For Linux, just copy the creality_cr6se.def.json
    from the github repository to: ~/.local/share/cura/4.7/definitions
    After that in the list of creality printers, the CR6-SE will appear.
  • Hi guys,
    I want to ask if also someone has trouble adding Cura profiles for the CR6 SE after after adding the profile of the printer in Cura.
    As i'm able to add the printer following the above steps, but when i'm trying to add print profiles, it says that it's added but it doesn't show anything.
    Thank you
  • @spauliszyn I got nozzle sizes. I made a set of changes before they showed (e.g., changed filename, added the word 'Nozzle', etc.), but ultimately landed on the configuration @speckone published. The folder may be important here, as i didn't even get an error until I put the nozzle size files in the cura configuration directory as described in speckone's readme.
  • Hi @speckone, I added all the files as your instructions and I still don't have nozzle sizes. Can I add them manually?
  • @Acd75 Good idea. I wish Creality would support upgrading to the latest software instead of just 'pinning' this post to let us fumble our way through it. I bet every one of their employees upgrades their smartphones as soon as there is a new version available so they should understand importance of keeping current.
  • Yes @rjamison, I did and I'm now running 4.7. Its working fine. Thanks so much for your guidance! ๐Ÿ™‚
    Sorry for the delay because I didn't get to it until now.
  • There is a typo in the file 'creality_base.def.json'.....if you edit it in notepad++......line 8..... look for "Absolute positionning\n\nG1 X0 Y{machine_depth}"
    I'm not sure if it is causing the issue or not, but it might be why I got errors and @rjamison did not, since he only copied the 'creality_cr6se.def.json' file.
    -Mike
  • I've updated the files from the Creality Slicer and posted them here:
    https://github.com/speckone/cura_cr6se
    This fixes the missing nozzle sizes from the extruder settings too.
  • @Stonedog03 I posted the steps I followed (did it again to be sure). Are they clear, and do they work for you?
  • @barney I posted the steps in the thread - are they clear?
  • I've ported the files from the Creality Slicer. I've got a working profile in 4.7.1 and even got the nozzle settings working after much trial and error. You can find the files here:
