Cr-6 se seems to have died
Has anyone else run into the issue that the machine stops halfway through auto leveling and will not do anything now? I assembled it per the instructions, booted it, kicked off the auto level and it died at number 8. I’ve tried rebooting (complete with pulling the power cord) - won’t even start auto leveling now. I tried to factory reset - no change. I tried homing - won’t even move. I have rechecked the tension on the belts and wheels and they are fine. I sent 2 emails to creality and have gotten no response.
Very disappointed with getting no response to either email.
They were talking about a similar problem in a different thread: https://forum.creality.com/topic/436/cr-6-is-stuck-on-auto-home-please-wait-for-minutes
Seems like Jecook got it to work by pre-heating before hitting the auto-level. Weird bug if that works.
Perhaps it works for you too?@Jecook said in cr-6 is stuck on "Auto home, please wait for minutes":
For auto-leveling, try pre-heating first. It sounds backwards, but that's what I did and it worked on mine at least.
Other than that, perhaps it helps to re-flash the firmware again?
Seems that admin suggests that for various other issues. Not sure if it will resolve this specific issue though.Please download the firmware here:https://www.creality.com/download
and flash the firmware as the following tutorial
Mainboard firmware flash tutorial: https://www.youtube.com/watch?v=AKIfwPgN0qs&feature=youtu.be
Screen Firmware Flash Tutorial: https://www.youtube.com/watch?v=Jswzrh2_ekkAlso, just to ask - Do you have any USB peripherals (Raspberry Pi, or other external equipment) hooked up to the USB port of the printer? You could try to disconnect that to see if it helps.
Here's another thread where they discuss auto bed leveling not working: https://forum.creality.com/topic/157/creality-cr-6-se-stuck-in-auto-leveling
Hope you can sort it out, and/or get a response from Creality officials.
