Have to load firmware every time to print
Every time I turn my CR6 SE it doesn't read file names on the SD card unless I load firmware when powering it up. Had anyone else encountered this issue? Once I turn it off and on again to print, the same issue - I have to load the firmware again.
First I have copied the gcode files on another sdcard in the route directory . To read filenames i encountered that little moving on the sd card solved this problem. then selecting a file is ok but after pressing start , nothing moves even with the default gcodes files copied from the original sdcard . I too encountered that a blue led on the motherboard ist fast blinking like data is moving to the screenunit, but no moves ...too bad
