Ender-5 Ender-5 VS Ender-6 VS CR-5 Pro: Which One Will Be Your Best Choice?
  • Ender-6 has created such a huge craze in the 3D printing community since its release. As the first Core-XY 3D printer, Ender-6 has been confirmed to unleash 3 times faster printing speed without sacrificing print quality. During the past few weeks, the most frequently discussed topic about Ender-6 is the available date and the price tag, which will be clearly stated in this article. Besides that, it will be a comprehensive product review and review on Ender-5, Ender-6, and CR-5 Pro, helping users to get hold of the major differences.
    Ender-5
    Ender-5 takes a clear departure from the compact frame used for the Ender-3. The box-like printer has outer dimensions of 440 x 410 x 465 mm and builds volume of 220 x 220 x 300 mm – so better make some room on your workbench. While the X and Y-axis measurements are the same as the Ender 3, the new version provides more room for the Z-axis. Each of the axes has a dedicated stepper motor. In a quite unusual way, the Y-axis motor drives both sides of the gantry at the same time so you get an overall smoother movement. The Z-axis is mounted in the middle of the bed with a big 8-mm-rod.
    Overall, the printer makes a sturdy impression. A Meanwell 350W / 24 V power supply (also to be found in the Ender 3 Pro) lets you heat the bed up to 100 degrees faster. The cable management is good – no loose ends here, so to speak. The printer runs a modified Marlin firmware.
    The price of Ender-5 oscillates from $320 to $350. On Creality’s official online is providing a discounted price at $319. For wholesalers who are interested in distributed Creality products, please contact us at info@creality.com
    Ender-6
    Ender-6, the Core-XY machine borrows technical aspects from the popular Ender-5 family, adds extra build volume, an enclosure, and several improved components. In terms of size, the Ender 6’s build volume of 250 x 250 x 400 mm puts it right between an Ender 5 Pro (220 x 220 x 300 mm) and the CR-10 series, which starts at 300 x 300 x 400 mm. This should suffice for the majority of your daily print jobs.
    Moreover, the surprising improvement that Ender-6 brings to the Ender series is acrylic plates on the four sides of the machine, which makes Ender-6 a semi-enclosed machine capable of extending the filament options. A simple mechanical bracket system holds the acrylic walls in place. The top of the machine isn’t covered as the print head is mounted here. Two front doors give you room to pluck your parts off the print bed once they’re finished. In addition, Ender-6 revamps its print bed with a Carborumdom glass platform, which is supposed to give users smoother first layers.
    Ender-6 revamps with a new look— an integrated all-metal chamber body and strong Creality-blue corner connectors, making the machine appear in quite an exquisite appearance.
    Furthermore, Creality provides another option for users who have requirements in printing a wider range of filaments. Ender-6 will be available in two versions, the one in open structure and the other with Acrylic plates in an enclosed structure. With Acrylic plates added on the four sides of the printer, Ender-6 will do better in preserving temperature within the print area, which will extend the filament choice from PLA to ABS, TPU, and more. Meanwhile, the transparent plates can still allow real-time monitoring on 3D printing process from 360° all around.
    Differences between Ender-5 and Ender-6
    The major difference between Ender-5 and Ender-6 is a mechanical arrangement. Ender-6 is utilizing a Core-XY structure, which means the machine is having a bottom-to-top moveable print bed, and utilizing two stepper motors to drive the motion in X-axis and Y-axis. The special mechanical structure makes it possible for Ender-6 to improve print speed without sacrificing print quality, and supply the exact same build volume while having smaller overall measurements.
    Ender 5 model offers a majority of the same capabilities as the Pro version. Plus, with the Ender 5 Pro on the market, the stock Ender 5 is prone to be discounted. For those looking to make a bang for a buck, this might be an opportunity. Ender-6 becomes such a powerful workhorse in the Ender series as it has inherited strengths from its predecessors and taken in new breakthroughs. It shall be an utmost choice for professionals, hobbyists, beginners, and everyone else to enjoy premium-quality 3D printing right out of the box.
    CR-5 Pro
    CR-5 Pro is the more recent version of the basic Creality CR-5, which was launched in 2019 and also noted the company's foray right into the globe of specialist 3D printing. It is a desktop-sized consumer-friendly 3D printing device efficient in creating industrial-grade prints while staying available to both specific makers as well as small companies. The machine is actually quite attractive in design. Its light-colored frame distinguishes it significantly from many of Creality’s other machines, which tend to be black in color.
    CR-5 Pro is a plug-and-play 3D printer that comes pre-assembled and is supposed to deliver ready-to-use quality prints right out of the box. It sports power-off print recovery, filament-run-out detection, and onboard operation guide. The all-metal case makes it sturdy and long-lasting.
    CR-5 Pro is having an enclosed build chamber, which captures heat to reduce or eliminate warping. The build chamber is not explicitly heated, but instead collects heat generated by the print surface and the hot end.
    Another feature is the general robustness of the entire system. They have built a sheet metal body that resists wobbling, and even include belts made by Gates of the USA. The result of these changes means the motion system can achieve an XY axis accuracy of 0.012mm.
    The processor in the CR-5 Pro’s controller board is an ATMEGA 2560, which is capable of providing “smooth motion” and “precise voltage control” during print operations.
    CR-5 Pro is designed to be a consumer-friendly machine that incorporates a number of important features that make it fit for families, schools, and individual makers. Operating in a print area of 300225380MM, it bets that CR-5 Pro will deliver industrial accuracy on your desktop.
    Differences between CR-5 Pro and Ender-6
    In terms of the targeting market, CR-5 Pro is designed to a semi-industrial 3D printer, confirmed to be capable of delivering industrial level accuracy on desktop; Ender-6 is a workhorse capable of delivering quality results at a 3 times faster print speed.
    CR-5 Pro is a cartesian axis system machine with a print volume of 300 x 225 x 380 mm. Ender-6 is a Core-XY 3D printer with a print volume of 250 x 250 x 400mm.
    Though CR-5 Pro and Ender-6 are both cubic design 3D printers, CR-5 Pro comes a pre-assemble machine, and Ender-6 comes in a semi-assembled kit which means that Ender-6 requires simple assembly before printing. Ender-6 could be a really great choice for hobbyists, and the CR-5 Pro shall be really suitable for schools and educational institutes.
    Ender-5 Specifications
    Technology: Fused deposition modeling (FDM)
    Year: 2018
    Assembly: Pre-assembled
    Build volume: 220 x 220 x 300 mm
    Min. Layer Height: 0.05 mm
    Frame: Aluminum
    Nozzle Quantity: One
    Nozzle diameter: 0.4 mm
    Max. print temperature: 260℃
    Nozzle diameter: 1.75 mm
    Connectivity: SD Card, USB
    Voltage: 100-240V
    Product weight: 11 kg
    Package Weight: 12 kg
    Product size: 400 x 380 x 400 mm
    Package size: 500 x 500 x 420 mm
    Ender-6 Specifications
    Technology: FDM
    Year: 2020
    Assembly: Semi-assembled
    Mechanical arrangement: CoreXY
    Accuracy: 0.1 mm
    Layer height: 0.1 mm
    Feeder system: Bowden
    Extruder type: Single nozzle
    Nozzle size: 0.4mm
    Max. build volume: 250 x 250 x 400 mm
    Max. extruder temperature: 260
    Max. heated bed temperature: 100
    Max. print speed: 150 mm/s
    Closed print chamber: Yes (semi-enclosed, optional)
    Bed leveling: Manual
    Print bed: Heated
    Display: LCD color screen
    Connectivity: SD card
    Built-in camera: No
    Resume Print: Yes
    Filament diameter: 1.75mm
    3rd party filaments: Yes
    Compatible materials: PLA, ABS, PETG
    Recommended slicer: Cura
    Operating system: Windows, Mac, Linux
    File types: STL, OBJ, 3MF
    Frame dimensions: 495 x 495 x 650 mm
    Weight: 30 kg
    CR-5 Pro Specifications
    Year: 2020
    Assembly: Assembled
    Mechanical arrangement: Cartesian XY-head
    Build volume: 300 x 225 x 380 mm
    Print head: Single nozzle
    Nozzle size: 0.4 mm
    Max. hot end temperature: 250 ℃
    Max. heated bed temperature: 100 °C
    Print bed material: Glass
    Frame: Aluminum
    Connectivity: SD card, USB
    Print recovery: Yes
    Filament sensor: Yes
    Camera: No
    Filament diameter: 1.75 mm
    Third-party filament: Yes
    Filament materials: Consumer materials (PLA, ABS, PETG, flexibles)
    Recommended slicer: Creality Slicer, Cura, Simplify3D, Repetier-Host
    Operating system: Windows, Mac OSX, Linux
    File types: STL, OBJ, AMF
    Frame dimensions: 530 x 487 x 612 mm
    Weight: 32.6 kg
  • @timd1971 , Probably, maybe in the future, I will collect all our customers' suggestions and feedback to the company. and really, thanks for your kind information. we will keep making upgrades on our 3d printer. and I also wish everyone can join us to make a more perfect 3d printer.
  • @admin
    Should have made the Ender 6 (PRO maybe?) Remote Direct Drive / dual gear extruder, dual z axis (supports both ends of bed, NOT cantilever!), FULLY ENCLOSED with clear TOP ON IT in order to print ABS, NYLON ETC easier. (Like QIDI) Filament roll inside enclosure. Come on, how hard is this, Creality can do this! It's FASTER CoreXY also!
    You know PRUSA XL CoreXY may beat you to this... but they WON'T be able to ship fast enough because too slow printing parts 24/7 instead of just doing injection molded parts.
    Ender 6... almost, but not it.... stop falling short... ALWAYS put MEAN WELL power supplies in your products. Quit with junk LANDY stuff!
    Thank you!
