5-Pro Silent / TMC Con Err / Solved
Hello
I just finish the build and got the error upon boot up.
I've flashed the machine with the file named "Ender-5 Pro- Marlin2.0.1 - V1.0.1 - Endstop.bin" and it did remove the TMC Connection Error message from the UI in the Ender Pro 5 with silent board.
I hope it helps.
Regards
CAn you please tell me how i can flash my printer using the the sd card that it came with? I insert the sd card into printer but nothing happens. i check "about printer" and it does show any difference. no update. please help
@sameerjc Hi, unfortunately since I wrote the post I have changed the firmware due to the installation of the BLtouch tool.
Did you check here for a newer firmware?
https://www.creality.com/download
Regards
@Tkgato
I did the same thing to resolve the issue however now my printer doesn’t show the resume printing option after power failure.
Do you see the same issue on your E5 Pro?
Dear @Tkgato
Thanks for sharing the information, I will make it to be pin post, that people will find it easier.
