Ender 5 Pro V4.2.2 / BLTouch / Display not working
Hello
I just installed the BLtouch kit from Creality and my display is not working.
There is only one way to connect to the Pinboard A the ribbon cable so I am clueless as to what is going on. Upon removal of the pinnboard the display works correctly.
I am running the latest firmware: V4.2.2-Ender-5 Pro-32bit Mainboard-Marlin2.0.1-V1.3.1-BLTouch.bin
Thanks for your help in advance!
@powerlines2000 Good to know! Thanks!
@Tkgato Yep discovered there is a design flaw, the case base fan presses against the BLTtouch cables if not really well cleared and dislodges the Pinboard.
Dear @Tkgato
Glad to hear that your issue is solved.
@Tkgato I just solved the issue by...well I have no clue, I guess you have to really push "gentle" which is not a good thing for monkey hands me. So, if you get the display not working, check and re check the connections on the pinnboard and good luck!
