ENDER 3 V2 Card V4.2.2 Filament runout wiring
Hello
I try to use the Filament Runout on my ENDER 3 V2 (Card version 4.2.2) and I have an issue. I think it comes from the wiring of the sensor.
Could someone confirm that it's as shown on the picture because I have some doubts.
Thanks
@Giancarlo-ITA
Thank you. I had still trouble and wanted to disassemble the board. SO i could fix now very easy. This pic is wrong!
For ppl finding this post. Its 3.3 V not 5V!
Yes, you also need to update the firmware and enable the filament runout , I installed marlin 2.0.7 and enabled the bl-touch as well.
Dear @micbri
The material break detection line is connected like this, the mainboard firmware needs to be refreshed to use the material break detection function
Ender-3 V2-Marlin-2.0.1 - V1.2.1 - Filament.bin
Hi
Yes, there is an error in the drawing, the red and white wires are reversed, if you look on the back of the card there is the correct writing. I also had the same problem as you, luckily no damage, reversed the wires and it worked right away.
