HELP ME PLEASE - nozzle never touching bed
Hi all,
I just recently assembled a brand new ended 3 pro.
I am stuck at the levelling part....
I level bed pretty much perfectly, however every time I go to print anything, the nozzle is no where near the bed.
Tell me what I need to do - I’ve been trying for atleast 3 hours to figure this out
I had the Same Issue, you have to cut the small "knob" on the Z-Endstop, so that you can set it low enough, otherwise itr will never reach the bed
Dear @hany
- Please check if the X-axis is shaking, and adjust with reference to the video: https://youtu.be/ml3CVKjdIIA
- Check whether the nozzle kit shakes, adjust it according to the video: https://youtu.be/cGXIU6HGzNQ
- Check if the printing platform is shaking, you can adjust it through the eccentric nut at the bottom of the platform
- After printing, adjust the printing rate to 20, and adjust the distance between the platform and the nozzle through the leveling nut
Just to be clear, you must first pre-heat the bed and do a home: then you disable the steppers and level the bed.
When you do a home, does the bed go down until it clicks the EOT switch?
