BLtouch incompatible with motherboard Ender 5 Pro
Hello there, I´ve just got my new Ender 5 Pro and the Bltouch for installing, I had done all the installation whithtou problems, but when I was about to plug the burner and the ISP Pinboard to the mainboard Ive found that there is no 2x3pins in the mainboard as the instructions says that has, the only pin there is in the place that is instructed by the manual is a 1x4 pin plug (Picture). What should I do? There is another way to update the firmware through sdcard?
Thanks!
I fitted mine last night, you dont need to burn the firmware on 4.2.2, jut put the downloaded firmware on the sd card and turn the machine on.
