CR10 s5 BL Touch loses z offset after homing
I home and set my z offset for my BLTouch. I save it to eprrom. If I Jogg the head around and go back to zero everything is fine, I can measure with paper and My z offset its fine. If I home all again the offset is wrong after homing and has to be reset with the tune menu.
@iHover After setting the z-offset, you need save this page, and then click into again, check whether the value of zoffset is correct.
If it is still the value set by yourself, it means that save is successful.
Go back to the origin and check whether the zoffset value on the display is the value set by yourself +10, if it is, that means there is no problem,
if not, try to update the firmware again.
