problems after Cerality CR-10 Max updating.
Hy guys
I
I recently updated my device Cerality CR-10Max with the official company files.
I have problems after updating.
The first problem with the touch screen is:- Values Parameter are not in place.
- Measures bed Leveling the 16-point rolling part while 25 points are placed in the display.
- In the print menu, the writings and values Parameter are messed up.
- 4- In the main menu, there is a problem with icon disabling step motor.
- The image is faulty when the device is turned on.
I attached the pictures
https://gofile.io/d/avNu4X
link textThank you for helping me.
thanks for your answer
@admin said in problems after Cerality CR-10 Max updating.:
Hi Alx,
I have sent you another one, sorry for the mistake.Thank you very much for your help.
Good luck
Hi Alx,
@alx Hi, As the document is too big, I send you again by email to EFTEKHARELC@GMAIL.COM. Please check.
Thanks
I just checked my email.
But the file you sent is wrong, please check.
@alx the motherboard firmware is refreshed, and the display firmware must also be refreshed. This is the refresh tutorial and firmware. https://youtu.be/7dqnfm4uC_U
Creatily_Marlin1.1.6_CR-10 MaxBLTouch_0729_V1.70.0BL.hex
https://www.dropbox.com/h?preview=DWIN_SET(1).zipHello
Thank you very much for your answer.
but The Dropbox link does not work.
https://www.dropbox.com/h؟preview=DWIN_SET(1).zip
Thank you for checking
Hello
This post is deleted!
