PC control
The only way to control the box is through the app? Can we do it through PC??
@Paolo said in PC control:
Yes from pc browser.
If an app can send to the box, i think there is a way to send from pc... the box is simply a wifi router with usb and lan ports. My idea is something like grbl sender or the app 3d fox printer controller.
@kromgr said in PC control:
You can acce to box via web in the same network ie. ip.192.168.0.101 (my box ip DHCP), user: admin password: admin.
The system platform is RT2880 embedded switch.
I read about sdk for this platfomr but i'm not able to make nothing of this.Using port scanner for my box ip i find this ports.
23, 80, 81, 6523, 8888.
I try to acces with putty telnet at port 23 but i don't know user and password.
It needs some research. At present I can't find a way into the box without damaging it. I want to see what makes it tick.
What I have discovered is that the USB port it plugs into is a USB/Serial converter, hopefully FTDi, so it should show up as a port in Device Manager.
As far as i can tell yes but it needs PC access or where you can load to the cloud from PC so you can get your files from your phone.
