CR10 S5 Z axis compresses bed 1.7mm
with bed 90 percent adjusted to its lowest level the z auto home still pushes the bed down approximately 1.7 mm. I adjust the z-offset to 1.7 and set home offsets and the z axis reads 0.00 however when I Auto-home, the print head homes 1.7 mm below the bed and when I check the z- offset it reads -1.7. what am I doing wrong?
Hello!
I would adjust the sensor. it is the one mounted on the z axix, left side. Lift it up as much as you need and find the perfect position.
