CR6 corrupts SD filesystem
I am having frequent issues with the printer corrupting the filesystem of the SD card.
The visible effect is that the .gcode are not visible and the Z-offset (previously set to 0.25) appears to be at 0.20.
The SD card seems ok at the PC, after I run the repair tool, the printer finds the file. This is happening more and more frequently using the SD card you sent me with the printer, I stopped to use a different card because it was permanently damaged.
Buying a new SD card every week doesn't seem a nice solution.
