After bl touch update printing wrong
hi ik did yesterday install en update the firmware, for the Bltouch.
Only the printmodel are going wrong.
The first layer go wrong, it seems me that Z as
Are wrong,
The frist printinglayer going wrong, and i have to stop the printer
@wim
Hi,
I assume you adjusted the Z-offset accordingly to the instructions for the BLTouch.I had the same issue on my Ender 3 pro. I solved it as follow:
You can adjust the Z-offset if too high. First, print a first layer and stop the print during this printing. Remove any filament under the head (HOT!!). Then in the menu go to Control - Motion - Z Offset and lower the value, step by step, until the distance between the bed and the head is fine. Then store the settings. Print a test layer. You can repeat this until you reach the best result.
